Discuss electrical box...does this exist? in the UK Electrical Forum area at ElectriciansForums.net
I need a particular kind of box and I'm not sure it exists (because of code I guess):
It's a box that will go over wiring connections that have already been made.(wires have been twisted together and wirenuts are on)
I want this so I don't have to dissassemble all the connections,put the wiring through holes in the box and reassemble everything.so does this exist? what's it called?
how many cables/connections?
Can you post a picture of what you are trying to box in, cover etc.
Loads out there...
here's a cheap and nasty type
here's a better one
but these are designed primarily for use with the correct connectors, not wire-nuts, however there's loads out there depending on exactly what you are trying to achieve
The OP is in the USA - wire nuts ARE the correct connectors! Note that the NEC has certain stipulations about junction box types but they are different from ours. There are all sorts of ways to kludge this with a plastic box assembled around the connections, but they probably won't meet code. Do it once, do it right.
Fair enough, Lucien...I know what you are saying, however I feel you may have misconstrued my comment.
I know that wire nuts are the "correct" connectors in the USA, in that they are in common usage. The Wago box is designed for use with the "correct" connectors, ie the Wago ones, which is what I meant. The OP wanted a box to put connectors in, didn't mention strain relief or MF.
Wire nuts are also common in Spain, just stuffed in a JB. It's common to see them put in a JB where one of the entries has been slotted to take them without undoing them and re-doing them. I'm not a fan.
Analog they don’t make a box with the back cut out of it. Are you an electrician and if not you need to find one. We have all types of boxes but them wires are hot and are they not in a box? If not that is a violation of the NEC and an experienced electrician could fix you up quickly. Who ever did that installation was not a licensed electrician, all splices shall be made in a sizable box, we don’t even know how many splices you have so we can’t even tell you what size box you need because of box fill calculations that have to be done
i suggest a wagobox, simplybecause OP would not need to disturb existing connections, but not sure if it meets NEC regulations.
Yes they make such a thing-
This is a standard j box as used by the Australian electricians.
If you are wanting a box to use to encase an existing wiring junction without having to undo the wires, then this is the thing.
you simply put the base plate behind the wires,
then you cut horseshoe shaped holes in the appropriate sides
to suit the wiring pattern
Then the cover goes over that and is screwed into place
Reply to electrical box...does this exist? in the UK Electrical Forum area at ElectriciansForums.net
I had done this about 30 years ago, and, IIRC, it was a series of boxes, Romex coming in, and Romex coming out, one in, one out, each box, except...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
