Discuss Electrical Box Sinkers in the Canada area at ElectriciansForums.net
I
ian
I am thinking of buying an box sinker (fits into a SDS drill) but i am not sure what they are like of if they are any good. Does anyone know.
Cheers
:D
They are ok on thermalite / breeze block or soft brick, they will do concrete blocks just take a tad longer, as for hard/engineer bricks forget it & stick to the bolster & scutch.
They also create alot of dust so I only use mine on newbuilds or extensions.
Mmmm, not so sure about these. The ones I have used have tended to break long before they have paid for themselves. Saying that though, I guess they would be usefull on new builds where thermalites have been used. (Carefull you don't find yourself in the cavity by accid.) But on thermalites you may as well just use your finger nails.:D
i have box sinkers. they can save you time. A bolster and lump-hammer do the trick nicely. A bolster without the shield soon makes a man of you. :)
Reply to Electrical Box Sinkers in the Canada area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
Hi all, Very much a novice when it comes to electrics. Anyway, we're getting an EV chargepoint installed, but before we do, I was wondering what...
We are a UK registered Electrical company with a large contract based in and around Toronto, Canada. Are you looking for work? We have a...
I am replacing some of the old receptacles in a 1940s house. Armored BX cable, two conductors, cable is the ground. Mostly pretty straightforward...
Our home is about 40 years old and equipped with original two Federal Pacific breaker boxes. Until now we have never had any problems. A 30 AMP...
