Discuss electrical consumption of an air source heat pump, Ontario Canada in the UK Electrical Forum area at ElectriciansForums.net
shira l
Hi - No idea if I am writing in the right place. Please, I cannot get a straight answer when the temperature is 0- -20 Celsius - where can I find a chart of what normal KWhr consumption is?
I think mine is using far too much electricity
thanks
Hi - no worries :) .
Here’s a link to the manual FYI, but a quick read of it didn’t seem to show any performance information.
[automerge]1573828292[/automerge]
Here’s a better one with some more performance data. Now I just have to have a cup of tea and read it :) .
Thanks so much I will read it over and try and understand
thanks
Shura welcome to the forum and there is nothing normal about power and most homes use about 11kwh per day and some homes use more and some less. Try and keep you usage around 9-10 kwh per hour.
Reply to electrical consumption of an air source heat pump, Ontario Canada in the UK Electrical Forum area at ElectriciansForums.net
We have just completed a self build, and heating system is Air Source Heat Pump, unvented HW cylinder, Buffet Tank, all Vaillant equipment. The...
Hello , I’m trying to further my knowledge into UFH/Rad/HW valves heating systems with air source pumps. What is normally needed outside with...
Hi guys We are due to undertake a new build install where they are using air source. Its the first air source I have installed so need a bit of...
My mother moved into her three bed home in 1960 and it had underfloor heating in the living room. I remember we used it when I was growing up in...
Wiring a new extension and the clients are having Air Source Heating in their house, I'm waiting to see what supply is required for it from the...
4K
