Discuss Electrical Engineer v/s Electrical Contractor in the Electrical Engineering Chat area at ElectriciansForums.net
Hi JS,
you'll have realised that this is a predominantly UK members forum, so what your situation is like in the States may be totally different, but here in the UK my personal advice would be to work within another company. Maybe then after a few years of experience you could branch out.
I would say that a lot depends on the demand in your part of the world for Electricians. If you can confidently assume that there is more work to go around than there are companies to do it all, then starting your own would give you better rewards eventually. If not then gaining experience is a must in an employed position. Working for yourself has many rewards, but not knowing what the legislation etc is in the states, i wouldnt know how much time you would need to factor in the things we need to do once the job is completed, and these things in the UK are plentyful and time consuming. You have to do a days work, then come home and do all the paperwork and so on.
Cheers...........Howard
I think the OP is talking about being an Engineer, rather than an electrician.
To be a fully fledged qualified Engineer you need experience, without it, you cannot gain your IET Chartered status (UK) or, in the case of the States full Registered membership of the IEEE...
Reply to Electrical Engineer v/s Electrical Contractor in the Electrical Engineering Chat area at ElectriciansForums.net
I start my BTEC Level 4 HNC Diploma in Electrical & Electronic Engineering in the new year, what book do you recommend to get to help me with my...
Alright everyone, Got a question and looking for some of your opinions. My brother is a qualified electrician and I'll be asking him the same when...
Hi there. I’m hoping for some advice. I currently run a small limited company that provides IT services, both commercial and domestic so I...
Hi, Just wondered if anyone knows whether there is such a thing as a distance learning version of the level 3 (C&G or EAL) Electrical...
4K
