Discuss electrical installation condition report(niceic ones) in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
V
virgil
at one of my inspections i found the boiler in the bathroom.the isolator is outside the bathroom,all the pipe work is tield around with a access hatch.so you just see the body of the boiler.the distance is a bit over 600 mm.What everyone think about this?shall i mention in report?shall i put as clasification code c.anyone can give me any information please.
M
Mark_Burgess
  • #2
Personally, I hate the zones of what you can and cant have in a bathroom, whats the chances of the boiler ever needing to be touched when one is wet?
It should be enclosed as moisture cant be doing it and good, but.......
A sticker on it stating NOT TO BE TOUCH WITH WET HANDS should suffice.
The 600mm distance is from what ......guess the bath/shower.
Is there a shower? If there is depending if it as a basin or not will determine your zones.
Again depending on your zones, will dictate what IP rating your appliance/boiler must be. Need a little more info really
Deleted member 9648
  • #4
As above...is it outside the zones....?.....is it RCD protected..?....is supplementary bonding required...?.....it's a bit more complex than the boiler itself just being there.
Recommendations:- Box in the boiler so it is enclosed and out of zones (if I've read your post correctly).
V
virgil
  • #6
it is 600mm away from the bath.the boxing is only protecting the pipes at the bottom of the boiler.so the boiler is not boxed in.it has supplementary bonding,not rcd.i will call tomorrow morning NICEIC technical helpline.if anyone want to know their answer let me know.
G
Guest55
  • #7
Quite common to see boilers in bathrooms , no real drama in itself , but i'd like too see it boxed in or in a cupboard or rcd protected if left out in the open.
If it cant get splashed and has the supplementary bonding connected i'd give it a code 3 with the reason as being unsuitable for the environment and not having a rcd.
As for the guidance you get from the NIC tech desk , i'd rather not know as its usually some insane drivel i rarely agree with lol.
V
virgil
  • #8
.page two of the domestic electrical installation condition report we have the colom 'further investigation required(Y or thick)'.tell me guys please,when shall i put there Y OR thick or to live that blank
G
Guest55
  • #9
You sound drunk.
V
virgil
  • #10
i realy thnik guys that you are here for fun,sad life,sorry but i realy think electricity and few of you are two things witch will never come together.please guys if you don't have anything to do with some things just look and move.my inbox will fill up
ipf
Mentor
I'd put 'thick'.
V
virgil
  • #12
can someone tell me if i get the corect table for t&e 6mm cable(the normal grey) in table 4D2A IN REGULATION-MULTICORE 70 DEGREES C TERMOPLASTIC INSULATED AND THERMOPLASTIC SHEATHED CABLES,NON-ARMOURED.IT IS RUN IN MINITRUNKING PVC AND I GET REFERANCE B AND I HAVE 38AMPS.LET MI KNOW IF IS CORECTELY.AND ALSO CAN YOU LET ME KNOW WITCH CABLE IS MULTICORE 90 DEGREES C
Reply to electrical installation condition report(niceic ones) in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Instyle LED Lighting Specialists UK
Top Bottom
