B
Barry
My name is Barry and I own a Business in Belfast called Citigolf. Citigolf set up in 2006 has 3 state of the art golf Simulators which allows anyone play real golf indoors with real golf balls and golf.
In 2008 I started to have a problem with one of these Simulators - Basically the sensors on the hitting mat (mat where balls is positioned) would start to light up on its own. The manufacturer said I had bad ground - and when all tests were done - showed all was ok - A new Electrical Box was fitted on the computer running the sensors - which solved the issue. This happens every 5-6 months and - Whereas an electrical box is supposed to last 5+ yrs - It was always changed and the problem stopped. Spikes on electricity was blamed as well as bad ground.
In the last 5 months this has started to happen every 3-4 weeks now. The manufacturer maintains its bad ground - But the thing is ground as required. Last week a stange thing happened. I touched, (lifted off floor) an electrical extension that was positioned behind the simulator and the sensor stopped lghting up as it should - gets even stranger - if I plug a Nintendo Wii on behind the sim - It stops & If I turn the store light on - it goes. I have no problem with any of the other sims. This sim is positioned right at the end of our building - close to the toilets, Store & outside.
Anyone able to shed some light on this - I have always dealt with computer technicians and its only in the 6 days I think its electrical interference. Is it? if so - What is the best thing I can do.
I appreciate your time reading this and even more so if you reply.
Barry
Barry
