Defcon
I'm just looking for opinions here on my uncle's farm. He had several new large outbuildings erected within the past three years. At the source, the sparky fitted an 80A 30mA RCD as the main isolator which protects all the other outbuildings at one part of their farm.
From here, they take a supply from an mcb to another building which has an enclosure with a 100A 2-pole isolator. This shed then has a supply taken from it to another outbuilding. i.e A-B, B-C,C-D.
The problem here, is the 30mA RCD. If damp etc gets into a light or switch, the other lot goes down and their well pump goes out to and thats a big problem during frosty weather cause if the power is off, the pump will freeze.
The sparky that did the job is now working in China but I asked another sparky who was doing work at a factory I was visiting and he said their isn't much that can be done as it has to be on a 30mA RCD since its TT.
I have a good enough knowledge of understanding electrical work but there are areas I am not clued up on. Cheers
