Discuss Electrical sockets compromising tanking system? in the UK Electrical Forum area at ElectriciansForums.net
Hi
We have had our single garage damp proofed (tanking system) it took a a good few months to work due to the amount of damp present(garage used to flood over time - back wall attaches to neighbours elevated garden 2/3 of the wall is agains ground).
we’ve had the tanking done and it has worked.
we have then had it converted into a room, the problem we have no is we’re concerned the tanking system has been breached, the electrical back boxes have been placed in the wall (so obvisojly there’s ahole in the wall where the box has gone) this has not been tanked.
I read online that dry line boxes are recommended Or the whole needed to be made tanked then the box glued in? Would this be correct?
also the skirting board has been drilled in with 8cm nails which we have measured goes straight through into the wall again penetrating the tanking system.
is this likely to cause problems with the tanking system and risk with the electrics due to the damp/water?
I think the first thing to do would be to call out the company that did the damp proofing and ask there opinion.
If need be, a quote to rectify any problems or a report stating the issues created by the new building works will assist in making any claim against the builders.
Hi
The electrition did know about the tanking but was working as a sub contractor for the guy who actually put the tanking system on, he told him where to put the sockets.
there was defiantly no tanking slurs placed behind the back boxes.
we didn’t think anything of it at the time it’s only recently as the project in nearing completion we were thinks where we could put things on the walls ourself then realised about the risk of damaging the tanking
As above, I would direct your concerns to the main contractor.
Hopefully the work comes with a guarantee backed by a trade body like the federation of master builders or similar.
Hi
I didan installation years back and the tanking firm supplied special plugs that sealed the tanking membrane as well as providing a decent fixing.
[/QUOTE
Brill thanks for the advise :)
What type of tanking has been applied/installed?
Is it a painted on solution, a chemical impregnation or the plastic sheets attached to the walls and floor?
[automerge]1593074884[/automerge]
Yes, I've had similar experience with the plastic sheet type tanking systems. They give you the special fixings, sealant and tapes, and will show you the correct way to install them if you ask/need.
Personally I prefer the approach of avoiding making any holes in it as much as possible.
Hi
They used KA tanking slurry.
The photo is when they started the tanking, does not show the full extent of the garage walls, but just an idea.
The plaster/Dry wall/flooring etc is all in now as well - but sockets were added after the tanking.
If back boxes etc have been sunk into the wall, how is the cable run to them? Is there some form of ducting already installed and incorporated in the tanking? If so would have thought back boxes should have been taken into account at the same time.
If the back boxes have been sunk in the wall and compromised the tanking then you can be sure that water will deep into the back box. This will cause future problems.
As above, you’ll need the tanking companyto assess the issue and suggest how if may be resolved.
Reply to Electrical sockets compromising tanking system? in the UK Electrical Forum area at ElectriciansForums.net
I have found out that my electricity supply in my external garage is wrongly connected to my neighbours electricity unit in their house and their...
Have a single plug socket which has been working fine for years. It is behind a unit so nothing has hit it. I looked at the socket and can seen no...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
