Discuss Electrical supply cable. in the UK Electrical Forum area at ElectriciansForums.net
jaserees
Hello.
Im in the process of making a cupboard for my consumer unit etc, and was wondering what the mains cable was wrapped in, and why. It looks like some sort of fabric.
[automerge]1568748245[/automerge]
Don't drive a screw through it when you're building your cupboard :) - there, you didn't expect good decent tips like that eh!?
The outer surface you can see is a layer called the 'serving' often made of impregnated jute, which protects a steel tape armour against corrosion, which protects the lead sheath against penetration, which protects the paper insulation against moisture. That's why it lasts so long.
Reply to Electrical supply cable. in the UK Electrical Forum area at ElectriciansForums.net
Afternoon All, Just pricing up a job and thought I'd pick your brains. Quick run-down, Block of Flats with an underground car park. In the...
Help please! I need a Tesla Gen 2 EV charger fitted in my garage which is 22m from the consumer unit. My electrician is proposing to route a 6mm...
Hi guys. I was wondering what size cable and braker I'd need for an electric shower. Just out of intrest am I close in guessing as follows: The...
