Discuss Electrical in the UK Electrical Forum area at ElectriciansForums.net
Hi All can any one Help advice. On my fuse board i have a 15amp fuse marked immersion heater.(not used) From this cable i would like to run a RCD fused spur for 150w underfloor heating. A fused spur for a shower pump and a 13 amp socket. Can this be done and what size fuse would need at fuse board.
Thank you
for what you want done, you should employ an electrician. then the circuit will be tested and a certificate issued. failure to provide a certificate would impact on your house insurance and any future house sale.
Reply to Electrical in the UK Electrical Forum area at ElectriciansForums.net
Hi, my friend is having a floating shelf with a electric fire, and I’m between minds where to put the socket, I was gonna put the socket behind...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
hi ive got an unused isolator in my airing cupboard that use to run a shower. no longer have has have combi boiler feeding a new shower. the...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
