Discuss Electrics down to the garage in the UK Electrical Forum area at ElectriciansForums.net
T
Toll
Hi everyone, I need to install 2 double sockets and 1 light in the garage 25 metres from the house. Would SWA 4mm 4 core cable do the job? (As I have got some 4 mm 4 core cable or have I got to have 3 core instead? Any help would be appreciated!
Do you think it will be okay? What concern do you have regarding this installation? Apart from the obvious of having to notify the Local Authority Building Control as per Part P of the Building Regulations ;)
The only concern I have is if the 4 core 4mm SWA cable can be used by a qualified electrician who I can employ to do the job. If the cable isn't correct I have time to get a different one. As you can tell I have no electrical knowledge and would expect the electrician to do the job legally and safely.
I will give a straight answer lol ,
yes 4mm swa will be fine , the extra unused core ( you only need 3 ) will be left unconnected
And I will contradict you :lol:
it might not be fine depending on where it is being taken from and the voltage drop calcs. But yes, I agree there is no problem having a "spare" core.
The only person who can really answer the question is the electrician who will sign it off.
that would be fine to use for your requirements
Reply to Electrics down to the garage in the UK Electrical Forum area at ElectriciansForums.net
HI folks, I'm on the management committee of the block of flats where I live. We've got ancient garage electrics and want to rewire. I have a...
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
Hi all hope u all have a fab christmas , my name is Nick and i bought a roller garage door it got delivered yesterday but due to holidays the...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
Hi all, I just found this forum last night and figured I would post my issue since I can't find much out there with a similar situation. My job...
