R
robert103
We have had a boiler removed from the bathroom and relocated. A whirlpool bath is now installed and there is a switched fused spur available (5 amp) which was used for old boiler.
I believe this is RCD protected as it goes back to the consumer board labelled "immersion heater" - is it ok to use this spur as this what the plumber has suggested?
I understand that this spur can be installed under tub as long as the bath panel can ONLY be removed with special tools/equipment i.e. so essentially it becomes an outside zone.
Is this possible? of course we will get a waterproof spur which cost approx £15 to be on the safe side.
Do we need a pull cord switch as we can not be removing the panel each time we need to isolate?
