Discuss electrode questions in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
solaker
hi all
I need to put an electrical supply to three steel containers sited next to one another. I intend take it to a db in one of the containers and feed dbs in the other two from the db.
Firstly is it ok to put one electrode in for the main db or does each container db require an electrode.
Secondly, I havent confirmed if the main earth system is tns or tncs but if its tns, are electrodes still required I presume they would be
Thankyou
Reply to electrode questions in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, I would like some advice on a scenario currently at my workplace. I am replacing a Sub main DB and replacing the wiring to sockets/lights...
On an EICR I found a 200 amp 3ph supply, TNS earthing (which looks original) and Ze of 19 ohms. No rods. No RCDs. L1 -> N was about 0.5 ohms...
Today I came across an earth cable from the earth bar in the DB that went directly into the incoming neutral side of the main switch. The DB is...
I’m a trainee electrician and would really appreciate the benefit of someone’s skill and experience on the following: Our house is a TN-C-S (100A...
5K
