- Reaction score
- 834
Hi Guys,
I was just looking over the requirements for the elesca assement. It says they need to see EIC's for the last 12 months.
Q1) If you were'nt registered before how would you do these works and sort out the part p?
Q2) If you did these works knowing you would be registered aventually, once you are registred, can you then sign off the work you've done over the past 12 months?
Q3) If you dont want to register with anyone but still do some notifyable/part p work, and go through the local building control, do they charge per job and is it a fixed price or does it depend on what the job is?
I was told that in Bradford it costs £110 to notify building control for part p for Installations worth up to £2000. Which isnt that bad if your doing a rewire but if your just installing an extractor fan in a bathroom and would normally only charge the customer £60, then you would have to charge the extra £110. That is alot of money for 1hrs work installing a fan. Or have I heard this wrong?
Any info would be great.
Cheers
Jay
Cheers
Jay
