Discuss Em lighting regs? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
sixfingers
Hi Are there any regulations regarding emergency lighting? The job is a split level shop with 1 x meter feeding 2 x switch fuses feeding separate fuseboards for the two levels of shop,emergency lighting has been fed just from ground floor fuseboard which feeds 2 x em lights ground level and 3 x em lights upper level so if power cuts from upper shop fusebord lights the em lights will not come on! Are there any regs to say this is an incorrect way of installation?
Thanks lenny great design guide,states(supply should be from the same local fuse as the normal lighting) Thats the way i have always installed em lighting! Was told today by sparks that the way he had installed it was correct!:confused: Cheers Know where i stand now!:)
Reply to Em lighting regs? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
Good morning all, I am currently working on a House in Multiple Occupation (HMO) consisting of 10 flats, with three parking spots equipped with...
