Discuss Emergency Lighting - Adding extra lights to circuit in the Lighting Forum area at ElectriciansForums.net
L
Liam Clement
Hi,
Hoping someone can give me some insight into emergency lighting circuits. I've never had to install an emergency lighting circuit, only testing of the circuit.
We have an emergency lighting circuit in place but I've been asked to add a couple of additional emergency lights to an area that has no emergency lighting currently.
I presume the circuit is similar to a normal lighting circuit, so am I able to take my feed from a nearby emergency light to my new couple of lights and then back to that emergency light?
Are you limited to how many emergency lights you can have in a circuit etc?
The new emergency lights need to be on the same circuit as the normal lighting in the area, they can be extended from the existing emergency light assuming the circuit can take the extra load and that it complies with requirements for emergency lighting (test switch etc). I'm not sure why you want to take a feed from it and back to it though? That doesn't sound like any normal lighting circuit!
Also the the type of emergency fitting and location need to be designed to comply with the current requirements, you can't just add a couple of lights randomly as there's every chance it won't comply.
Hi,
Request Rejected - http://www-public.tnb.com/eel/docs/emergilite/Emergi-Lite_Emergency_Lighting_Design_Guide.pdf
I would reiterate that part, although the rest is also relevant.
You need to design emergency lighting carefully. Think about what you need to show on the certificate has everything been covered?
A diagram I did before to show one way of doing various types of self contained emergency light wiring.
Hi,
Thanks for the quick response!
I understand the new emergency lighting has to be on the same circuit as the lights in that area and the test switch being necessary but as far as the requirements for the actual lighting I was advised that it simply had to be "suitable and sufficient"?
The diagram is useful, thank you.
My background is electrical maintenance in manufacturing (injection moulding, CNC's, automation etc.), haven't had a great deal to do with the domestic side of things. Did my 17th edition etc. a few year back but never really put it into practice. So I'm a bit out of touch to say the least.
With the information you've provided I should be able to add these new emergency lights in and I'll brush up on the regs.
I wonder why emergency lighting installations, and fire alarms come to that rarely comply to current standards, I wonder. It always amazes me most sparks have BS7671, well they generally have to but when it comes to safety systems it is like BS7266 and BS5839 just don't exist.
Reply to Emergency Lighting - Adding extra lights to circuit in the Lighting Forum area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
