Discuss Emergency Lights 30 cm away? in the Electrical Forum area at ElectriciansForums.net
Thanks again Westward. It seems that the emergency light does not have to be 30 cm away from the light, right?You already have a thread running on this topic. If you are installing emergency lighting you should know this. Why is an automatic detector affected by adjacent obstacles and does this apply to emergency lighting.
Westward I have bought the lights that are to BS5266 standard, I am just wiring them to the light roseAre you designing this or doing it to spec. These are safety systems and should be installed to BS5266:1.
Oh ok. I've just had a quick look on the internet but don't understand it. Will look at properly another time. ThanksThe lights are not made to BS5266 but the installation is designed to it. So you have designed the system and will commission it as per this Standard?
Westward I have read more. It seems that I can just connect the live and neautral to the light circuit. By design I suppose you mean where to place them. it's a terraced 3 level house. I can place them near the light on the 3 levels and the extension so that they light up all the passages and reflects the light 20 metres away.The lights are not made to BS5266 but the installation is designed to it. So you have designed the system and will commission it as per this Standard?
Thanks Tim I have read more. It seems that I can just connect the live and neautral to the light circuit. By design I suppose you mean where to place them. it's a terraced 3 level house. I can place them near the light on the 3 levels and the extension so that they light up all the passages and reflects the light 20 metres away.I'm assuming this is a commercial job if multiple units are being mentioned.
There's quite a lot more to the location of emergency lighting than how far it should be away from other things.
Off the top of my head things like
-what does the fire risk assessment say
-where do escape routes change direction and level
-how wide are corridors
-which stairwells are escape routes
-even how big are the toilets!
...all play a part in dictating where you need them, how many you need and how bright they need to be.
If people 'fail to escape' you can be held liable as the designer. If you can't prove competence or experience with BS 5266 then in the nicest way possible you might want to protect yourself and reconsider this job, or at a minimum tell the customer that you want to see the FRA and you'll need to consult whoever did it to approve your plans to ensure they (the customer) cannot be held liable for any errors of judgement.
Well you seem determined to do this no matter what we say. Connect live and neutral possibly more to it than that but your choice. There are many people out there who install these systems with no knowledge of BS5266 because it is just wires, I'm an electrician how difficult can it be.Westward I have read more. It seems that I can just connect the live and neautral to the light circuit. By design I suppose you mean where to place them. it's a terraced 3 level house. I can place them near the light on the 3 levels and the extension so that they light up all the passages and reflects the light 20 metres away.
Thanks @Vortigern It's a large HMO. The council have asked for these Iluminaires to be fitted to BS5266.1 standardAs I think @westward10 was alluding to, the placement of emergency lighting it prescibed by BS5266. Pretty much as @timhoward has listed plus a few more items such as luminance from photometric data usually supplied by the manufacturer. As you may know lights can contain emergency/anti panic lighting so distance is not an issue. As to just connect live and neutral, again it is not as simple as that. It requires two lives one being switched and a neutral so you will need to think about what you are doing a tad more. Is this for you? What kind of premises is it in? Why do you even need to fit them?
DPG I can only do simple electricsAnd are you competent to do this? Do you have a good working knowledge of the standard and how to install to it?
Reply to Emergency Lights 30 cm away? in the Electrical Forum area at ElectriciansForums.net
