Discuss Emmersion boiler switch - will this do? in the DIY Electrical Advice area at ElectriciansForums.net
Dormouse
Last week the light on the switch wouldn't light up so I replaced the fuse. Since then the rocker switch started playing up and it would only light when in mid way position. Tonight it wouldn't light at all and when I removed the fuse, it was all burnt inside. I have inserted a new fuse and it works but I guess I ought to replace the front of the unit. I have purchased the following from Amazon and would like to check if you (ie: qualified electrician) think it is OK? The fuse is 13amp and I understand I probably need to turn off the electric from the main trip switch to change it (even if I don't need to, I'd feel safer!)
Many thanks
DM
13 AMP WHITE FUSED CONNECTION UNIT SPUR DP SWITCHED WITH NEON LG9218N: Amazon.co.uk: Lighting
If I was in your shoes, I would get an Electrician in to have a look, before you get hurt, wont cost much
also, if it's on it's own circuit with 16A OCPD, the a 20A D/P switch with neon would be a better option. as methuselah^^^^^ said. get a local electrician to sort ot for you.
---- me Promotion
Many thanks
DM
There is no probably about it you will at least need to turn off the circuit and should be locked off to ,this is to prevent re energizing I would do as Pete and tel have recommended and get in a qualified spark
Some three years later ....... thank you, I did and I live to tell the tale! Better harassed than dead or badly injured.
Reply to Emmersion boiler switch - will this do? in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
Hi. First up, I am not a qualified electrician so this is a DIY project However, I am physicist by training with a specialism in...
8K
Hi guys came across something I've not seen before and has me puzzled. I've tested quite a few emergency lighting systems over the years but I'm...
The neon light on my flat-plate/switched fused connection unit doesn't come on when I use the washing machine. The machine still works - but does...
9K
