The wifi router is under the wall thermostat just 3 foot below it, the Energenie hub is sitting on the router, all three about centre of the house.
To alter on the phone it all works A1, turn up the wall thermostat and all the linked TRV heads auto change to same temperature.
However change with the PC or with a set schedule, and it's hit and miss, some times they follow, and some times they don't. The problem is if I turn up the temperature then the boiler is running, but TRV heads have not opened so boiler starts to cycle and pump may start to cavitate as TRV heads are closed.
So at the moment the TRV heads are simply set to same schedule as Nest or a higher temperature to Nest, never lower. So pump will not cavitate and Boiler cycling kept to minimum.
So my £45 Energenie TRV heads are not doing as good as a job as my eQ-3 programmable heads which only cost £15 each with bluetooth, but I find I don't use bluetooth once set up, I walk into room and press the comfort/Eco button which swaps from 17°C to 21°C until next schedule change.
So sitting in my bedroom at moment, eQ-3 TRV head set to 21°C the thermometer next to me says 21.3°C and old unused programmable thermostat other side of laptop shows 21°C so the cheap TRV is doing a really good job.
Rest of house target and current within 2°C of each other, and only shows whole numbers so likely closer.
