doodarr
Hi guy's
Had a call from a friend. His house has a lighting circuit :bulb2:- passage (1G2W) & living room (1G1W) - the passage is first from CU then continues to the living room. However, the passage light has a spur from the orginal light using 1.5 T&E from rose to rose. Now the additional light (Spured light) has a delay of almost a second when the switch is turned on, is this just due to both lights having enery saving bulbs or do I need to go over and have a look?
Thanks in advance.
Thanks in advance.
