Discuss EOL in fire alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
C
crabapple
on detectors/BG is EOL device connected across N and L in?
also does polarity matter, its got a red leg and black leg
on sounders is the resistor just connected on L an N
im using a 4 zone new esp conventional panel, its been a whle since i last did one
EOL monitors connected to detectors should be connected to out connections (This enables monitoring of final detector head, and will send fault signal to panel if removed). Not sure if polarity is important, but i would always have Red +, Black -.
Yes, Sounder resistor is connected accross L + N (+ & -).
between fire panel and cu i have a red unswitched spur
i am right in using 1.5 TE from cu to spur
FP cable from spur to panel
or does it matter???
I am not fully educated on FA regulations.
However, my understanding is that the power supply to FA panel needs to be fire rated all the way back to distribution board, as is often recommended to be connected to first distribution board at intake position.
The isolation should also be a key operated switch with neon. I usually use MK K963KOALM.
Personally, I don't understand the purpose of fire rated power supply cable as the FA panel has backup batteries and in the event of a fire, the supply cables (meter tails) would breakdown and disconnect the supply.
Reply to EOL in fire alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
Hi, I need to extend a fire alarm, the panel is a CTEC CFP 2 zone one and currently it has a couple of apollo alarm sense sounder bases/heads on...
4K
On this commercial building we are refurbishing it has the above fire alarm panel which I think is pretty much brand new, I'm not even sure it was...
Hello People Our Enphase solar system needs to have the AC supply shut down via the fire alarm contactors local input output unit that has NO &...
I am doing renovation to a cafe in Scotland at the moment and after speaking to the local council the building requires the minimum standard for a...
