Discuss EPC Life span in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
A
andypipe
We have just won a job, and upon checking, the property has an EPC from early 2008. seeing as this is the 1st install we have carried out on a property that has an EPC in place, will this one be ok or should it get re evaluated?
It will be fine as long as it's band D or above. No need for extra expense.
are you sure?
I had it in my head that there was some sort of 3 year rule for FIT purposes, but I may well have just made that up.
I just checked the Ofgem guidance and can't find any reference to anything other than the 10 year validity, so I must have imagined the 3 year thing.
Reply to EPC Life span in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello everyone In September 2023 I rented a beautiful 3 bedroom apartment, with all electric supply, no gas powered appliances. I noted down the...
Hi all. I have a small question about inspection interval labels. We all know to fit one of these labels with the relevant date upon completion of...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
Hi guys, Had an issue at a recent survey where doing a quick check and found we had pme with a reading of 0.44 ohms. Called the network and they...
