Discuss EU confirm? RCM10CR electric oven for Germany in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
brit
Hi everyone, I am a normal end-user, I like cooking and I felt in love with an electric oven Leisure RCM10CR. Installing it in the UK wouldnt be a problem, but I am relocating to Germany and I like to ask you all, if there is someone who worked on the continent and can tell, if there is something special to connect an oven in Germany? I will hire a professional electrician in Berlin and some more upfront infos could be helpful. I am posting my questions also on a german electric forum, but no one ever did this before and questions appear like:
Do English houses have a special fuse for ovens?
In Germany ovens are extra fused with 16A. Would this be enough or do we have to downgrade?
How should be the connection from oven to a power socket?
I know, you are not allowed to connect your oven yourself as the end-user unless you are a certified electrician, fair enough. But it would be nice to get more technical information for my German electrician than what is described in the manual.
Thank you!!
hello, now nearly a month ahead, I want to say, that there was no problem to connect the oven.
I had my cousin to connect this oven and it was so easy for him, that I didnt had even a chance to take a photo. We have oven cables in Germany which you can buy in every DIY shop, with a power plug on the end and loose 5 thick solid copper cables at the other end. If you have a bit of electric knowledge and able to change a plug, you can also connect an electric oven.
thanks
ps: all smaller UK electric ovens (normal size with 4 cooking places) come already with a cable to "plug and use". So I think the procedure for the wider electric ovens with no cables comes possibly from the more often gas&electric connection regulations, where you obviously need a Corgy Specialists and can't and shouldn't do it yourself. For the big electric ovens, they could change the regulations however.
Is the person that fitted the oven an electrician? Might be worth getting an electrician out to check that it is fitted correctley. I'm a bit concerned that you might be overloading the cable.
He is not an official electrician, he builds electric automated systems, so he knows what he is doing. Thanks for your concern. So far I did not had any problems.
Reply to EU confirm? RCM10CR electric oven for Germany in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello hope you can help I have a single oven 2.4kw max and a ceramic hob 6kw max I would like to put then both on the same circuit so i was...
Hi, I've recently had my broken oven replaced in my flat and I paid for delivery and installation. It was hardwired through an unswitched plate...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hi all Some advice on this would be great. Due to wire a kitchen from scratch and in a pickle over the designing of the oven and hob circuits due...
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
