Discuss EV charging points advise needed in the Electric Vehicles Advice Forum area at ElectriciansForums.net
J.C.E
Evening evening!
Been giving drawings for some flats which also need 3x ev charging points outside
no spec given atall as yet!
Just wanting to get clued up before hand
so for something like this- Rolec EV Charging IEC WallPod 16A HomeCharge EVWP2010 | RS Electrical Supplies - http://www.rselectricalsupplies.co.uk/rolec-ev-charging-iec-wallpod-16a-homecharge-evwp2010_9486
simply just a 16a SWA radial on a mcb as the unit has the built in rcd (is it A type?)
if the system is TN- then am i right in thinking I need a rod for each of the chargers
cheers for any insight
Evening evening!
I would wait before commenting until you get hold of the specification for these units.
See Section 722 of BS7671, the IET also have the Code of Practice for Electric Vehicle Charging Equipment.
I was about to post the same , but I am having trouble scrolling and posting on the site .
I am using opera , and have just tried IE.
Ie was ok before ,but is now doing the same .
DITTO !
I would look into it carefully first
especially the amount of power used 16 A seems a little light on !
What is a Tesla Wall Connector?
The Wall Connector can be installed on a circuit from 6 to 32 amps
Evening evening!
Believe its with PME supply, where TT is suggested, albeit there's a get out of jail card in reg 722.411.4.1!
If I was doing some, I would purchase and read the COP, as westward suggested.
are you referring to 722.411.4.1iii ?
is this a 'a type rcd'?
Nope not exactly;
722.411.4.1, 'The requirements of this regulation need not be applied for charging point at a dwelling, if none of (i), (ii) or (iii) is reasonably practicable'.
Seem to remember there was another thread on this subject, not so long ago, where that sentenced was debated back and forth. I still don't understand it.
As said, never done one before, but if I did, think I would obtain that COP and have a good read.
Nope not exactly;
also goes on to say what their def of dwellings is......would 9 flats over 3 stories be classed as dwelling?
Reply to EV charging points advise needed in the Electric Vehicles Advice Forum area at ElectriciansForums.net
Help please! I need a Tesla Gen 2 EV charger fitted in my garage which is 22m from the consumer unit. My electrician is proposing to route a 6mm...
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
Afternoon all, and apologies if this has been covered elsewhere, but a search didn't bring anything up. Just a quick heads up to anyone...
So I am a fully qualified spark with my own company, however I also have a few properties I rent out. One of my tenants asked if they can have an...
10K
As the title says, does a three-pin socket (external) used as charging point need an earth electrode or open PEN fault? Are mode 1 and mode 2...
5K
