Discuss Existing basement back box fixings in the UK Electrical Forum area at ElectriciansForums.net
J.C.E
Morning
How is a good way of fixing back boxes to existing solid walls of basement flats.
Builder said no fixings but need to ‘glue’
They are just dot dabbing exisiting walls and the finish is white plastic- so will get away with 25mm so no chase needed
use the muck they stick the boards with. surround the back boxes with it.
Morning
Why is the builder stipulating "no fixings"
As tel says, use the board adhesive or Pink Grip is quite strong. Only problem is holding them in place whilst they set. You might have to put quite a bit on to make a good firm fixing as well.
Jay
Reply to Existing basement back box fixings in the UK Electrical Forum area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
I'm currently refurbishing a room and in the process adding some internal wall insulation. The wall has been stripped and my electrician has...
Hey everyone, I'm trying to understand how to fit a metallic back box on a stud wall. Should it be fixed to a stud (on one of the sides) or is it...
5K
An odd question granted but bear with me. I've got to extend a radial circuit in a community centre to fit a new hand dryer in the toilets, but I...
