Discuss explaining earth/neutral in the The Welcome Forum area at ElectriciansForums.net
B
beanzntoast
Hi,firstly just to introduce myself which i think would be rude if i didn't seen as i'm new to the forum & asking for advise,i'm jason & through studying & self taught i have learnt & found out quite alot about electrics with alot more to learn,i am on a course studying 2330 level 2,3 & nvq level 3, the question is on a TNC-S earthing system am i right in saying that the neutral & earth are connected together at the supply side only & they seperate at the consumers side to give two seperate conductors,if this is correct what advantages does it have over a TN-S( why is it used more than the TN-S on new installations is it supposed to be safer because it is connected to earth at various points from the supply transformer).If this is true could somebody explain how come at the points where it is connected to earth by the use of earthing cables running down the side of wooden electric poles on the supply side,that why at these points they dont carry voltage/current to earth when the neutral returns the voltage/current to the transformer(i'm obviously missing something somewhere):confused:.if i've got this wrong i apologise in advance but if so could somebody correct me
cheers jason
Hi Jason (fantastic name by the way) and welcome to the forums..
Best thing is to create a new post with your questions in the relevant forum.
Cheers
Hi,
Warm Regards,
Peter
Reply to explaining earth/neutral in the The Welcome Forum area at ElectriciansForums.net
Having a challenge understanding the concept behind why when you measure across line and neutral (live circuit) using voltage indicators we have...
Hi everyone, Quick question can you fit an RCD without any neutral connections? If I have a 3 pole circuit breaker which has all 3 poles...
Hi. I've read much about ac vs dc but can't find a 'simple' answer. If current alternates 50 times per second in a uk mains circuit, why do live...
Hi all, Hope you're keeping well I'm currently wiring a small commercial premises. 3 phas incoming supply, 16sq cables As it is in an urban...
Hello All I was pondering an idea recently regarding the ground connection to my property. At present it has a combined Neutral to earth at the...
