Discuss Export or Import in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
G
gazandwiz
Hi All.
New poster here and I'm posting because of the bewildering amount of differing information I'm finding on the internet.
My question is; How do CT transformers on the PV 'out' and the import meter 'in' know if there's an overall excess of deficit?
I've been looking at the Owl Intuition product for monitoring import, generated and exported totals, but can't work out how it's done if the CT transformer can't determine the direction of flow.
I have two arrays with two inverters. 3+1kw and am currently using an Owl CM119 to monitor the total generated from both arrays. I have the Live of both arrays going through the single CT transformer. My understanding of the OWL Intuition product is that it has 2 CT's and it looks at the difference between them when one is between the consumer unit and the import meter whilst the other is on the PV side. I can see two scenarios where the difference would be identical but the flows opposite.
1. I generate 3kw and have a 2kw load from my house. Net difference 1kw being exported.
2. I generate the same 3kw but have a 4kw load on my house and since the flow direction can't be determined the net difference is again 1kw, but in this instance I'm buying it from the power company. Wouldn't this mess up the statistics for the totals?
Have I misunderstood something? Does the Owl really work this way? I have emailed Owl, no response!
No doubt any responses will stimulate more questions, so if any one knows of a technical site that fully explains all this, I'd appreciate a link. You can't trust those making money out of selling kit for info!
Cheers
Gary
For the best answers as to how the CT's work have a look at this site, it'll tell you "Everything You Wanted to Know About .... Energy Monitoring" including what's up with Owl's and all the other standard off the shelf energy monitoring devices, why they are so inaccurate and why they don't know which direction they are coming from :)
Home | OpenEnergyMonitor
especially read the forum posts : Forums | OpenEnergyMonitor
And the site is free!!
See my other posts re Immersion heater stuff, all the meters that use CT that we have used also have a voltage and phase angle sensor - there is a sensor link to each of the phases.
Reply to Export or Import in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Greetings, everyone, After dedicating over a month to researching Solar PV systems, I'm nearly ready to make a decision. I owe my progress to...
I currently have solar array and was going to purchase Shelly EM to monitor Grid in/out and solar production. So far so good. But I also plan in...
Hi all, We have a 3.9Kw array (13 x Sapphire 300W Black Mono solar panels) on our roof with a Growatt 3600MTL-S mini inverter. All good and has...
Hi all Is anyone aware of the change to solar generation FIT payment contracts for existing installations. (FIT payment scheme closed in 2019)...
We have 10 energy meter in that 4x of them are giving the negative reading. The events shown are two 1is Negative Power Element 2 Warnings & 2...
