Discuss Exposed T and E's during test. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, I am new to this forum and can't find an exact match to my search.
I am new to testing and inspection and have come across a db mounted in a garage on the wall whereby the t and e's for all circuits are clipped direct to the wall before entering the ceiling approx 1m above.
Is this deemed as a C2 or C3 on test cert?
Thanks.
What do the regulations referenced in section 4.16 have to say about the example of wiring you are inspecting ?
Hi Andy. Thanks for your help on this. Really appreciated. I have re-read the sections in the regs and they refer to mechanical strain, not mechanical protection as I had read it earlier too hastily.
The outer sheath is classed as mechanical protection. The environment the cables are installed in will dictate if it is sufficient mechanical protection. For example T&E clipped on a wall at high level with nothing around it would not warrant any code. T&E clipped just above a shelf used for heavy items may warrant a C2/3.
Thank you. I perceived the regs incorrectly.
A code maybe deemed necessary if the top of the consumer units IP rating (IP4X) is compromised where the cables enter the enclosure
might not warrant a code, unfortunately there isn't a code for an eyesore. it's R.A.F. ( Rough As F*CK)
On an older existing installs I am not overly fussed about clipped direct so long as it shows no evidence of damage.
I have clipped twin and earth in my garage from new been there for 30+ years and absolutely fine with this.
Same with older installs with non rcd on the lighting I am not overly concerned.
I have non rcd lighting.
Now if in the OP the cable sheathing was all chaffed and bashed up I would suggest so over capping
Reply to Exposed T and E's during test. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Afternoon everyone.. During some testing I have found an IR reading of 0.01MΩ between N-E. This is on a length of SWA buried underground from the...
I have a TPN board that will feed 8-10 sub boards. The loads on each board are negligible 5-10 amps peak but mostly 1-2 amps. The distribution...
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
