Discuss Exposed wires in the UK Electrical Forum area at ElectriciansForums.net
Hi all, a local electrician has installed a bulkhead light, the wires go in through holes in the fitting, there is no "gland" as we have on other fittings, just 2 small open holes through which the cables pass, I have queried this as being a way for insects and potentially moisture to enter the fitting, also the coloured inner parts of the wires are exposed and the copper of the earth wire is visible. I clean around the fitting with a brush on a metal handle (as most broom handles are these days).
The electrician says its fine, and I am being unreasonable to query the installation and I should get a different brush to dust with.
Am I being unreasonable?
No you are not unreasonable, an awful job, how much in labour did he charge? get him back if possible and re install properly
Hi guys, thanks very much for your quick responses, he is adamant it doesn't need changing, are there any regs I could quote to have a last crack at him doing it properly before I move on and pay someone else.
Ask him about the IP rating of the installation ( IP, Ingress Protection) not sure of the Regulation number, but it's clearly a rubbish install and he should be ashamed of himself clearly not a competent Electrician. The only Ref I have eyes on is Appendix L ODG On site Guide Page 207 and Guidance note 1 Selection and Erection
I often wonder if people like this know their work is utter carp
or wether this fella went home thinking it was right good pukka job
did he stand back and say wow what a beautiful job that was with all the cable hanging out and a big hole in the side...
I reckon he knew it wasn't right but just wanted to get it done as quick as he could.
Yes makes you wonder doesn't it??
[automerge]1580748717[/automerge]
Take the cash and run you mean Mate????
looks to me like the light is a replacement. if so you can't blame him for the conduit and trunking. he could have just got a bigger light and made the cable entries compliant.
Steve I think you need a real electrician and no your not being unreasonable. For your info they make what we call duct seal to seal up holes. Good luck my friend
At the very least, why didn't he butt the light up to the conduit and trunking and drill the holes where the cables came out of the conduit/trunking? The right hand hole is no where near the trunking!
Exposed single insulation is a C2 on a condition report, so for that reason alone it is not satisfactory.
Reply to Exposed wires in the UK Electrical Forum area at ElectriciansForums.net
Hi all! I'm not a spark but know enough to be able to install off grid solar etc. I've just purchased a new house and have noticed the consumer...
5K
Good evening all, I’m currently part way through my apprenticeship and we are working on IB, IN, IZ and IT and volt drop today. And it got me...
Hello. I'll apologize to start with as due to my lack of knowledge on the matter I'm likely to waffle a bit and call everything by the wrong name...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
I have an older Crouse Hinds board with a 200A service. Due to recent rehab on the house, I found I have the need to install a sub panel. I...
