CK Tools :) The professionals choice when it comes to Electrical Tools
Discuss Extending 10mm shower cable in the loft ?? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
jimmyclew250
Hi
Can I have some advise
Can I connect via junction box or similar 10mm shower cable in the loft as moving the shower and dont want to replace the whole cable? (but moving the shower will result in cable being to short )
Is this allowed and what will I need
Best Regards
Jimmy
Yes you can join the cable, if you use a JB, you have to be able to get to it, Like any join. its awlays best to not join if possible but if you have to its ok
darkwood
Mod
Mentor
The professional way would be 10mm through-crimps with heat shrink insulation sleeving over the crimps and individual cores and a further sleeve heat-shrink with moisture barrier covering complete joint with overlap.
alternatively an adaptable accessible box with din rail mount, 60amp dinrail mount connectors and fully labled up lid.
darkwood
Mod
Mentor
Also welcome to the forum and from your query i assume you are not an electrician but due to the nature of this heavy load i would consider professional help as in call an electrician as a poor joint could be a fire hazard, he will also check the existing is safe and complies with 17th regs. Peace of mind that your family is safe using shower is always worth the cost.
To note also is the shower is in what is regarded as a special location and it is illegal for you to wire or alter any circuit to such locations.... so call a qualified registered electrician.
Jimmy Boy
Unless you are a competent person and can carry out the work and required testing to the requirements of the regulations I would leave well alone TBH
J
shocking_eg
  • #6
as above post, i would use one of the large 60A Junction boxes to extend.
not like your adding any more circuits or anything just simply moving the shower
if your not sure about things then get a sparks in to do the job.
Jimmy Boy
I can't believe people are encouraging him to do this ! He's extending the circuit,which effectively means he needs to do all the testing on it ! Tell him to go to B&Q and ask someone in an Orange jump suit lol
J
shocking_eg
  • #8
of course he needs the testing done after moving to verify the circuit.
but the chances are if hes asking this question he wont have the equipment to test.
but 90% of the time they will still go ahead and do the job no matter what advice is given !
i have come across a 10KW shower extended using 30A connector blocks with tape.
there wasn't much left of the connector blocks lets say ! lol
darkwood
Mod
Mentor
not like your adding any more circuits or anything just simply moving the shower.
If you are making alterations, extending or making additions to a circuit in a special area as the OP is then it is notifyable, what if the existing is without rcd and/or dosn't comply in other ways, with your comments you have just told a DIY'er to put his family and house at risk, poor advice in the least.
Its easy to have opinions regarding certain jobs but as a forum we should sometime refrain from our own views to give good advice.
shocking_eg
  • #10
If you are making alterations, extending making additions to a circuit in a special area as the OP is then it iis notifyable, what if the existing is without rcd and dosn't comply, with your comments you have just told a DIY'er to put his family and house at risk, poor advice in the least.
I get it...all my fault now ! haha some of you guys on here make me laugh.
at least if hes going to do it, he will use a proper JB and not some choc blocks or something !
FFS !
get shot down for saying anything on here. god knows why im even on here !!
Jimmy Boy
I will stick my head above the parapet ...I don't think professional electricians should be advising people,that usually, but not exclusively are DIYers on how to carry out work that is way beyond their ability,it's dangerous,some what irresponsible, and is bad for the trade, I wont say I have never done it, but not any more, it's getting like a DIY forum on here for have a go sparkies, not good IMHO. Some will disagree with me but thats my take chaps sorry.
ATB J
shocking_eg
  • #12
surely these forums shouldnt be out there then if advise shouldnt be given to the less knowledgeable people out there. if your qualified you should already know all of this sort of stuff.
i think there would be less dangerous DIY work if they didnt pick up ideas off the forums ??
Jimmy Boy
What could be more dangerous than a circuit like that being extended, not tested, no earth possibly, no RCD functioning , Zs crap, disconnection time out the window, someone stands in bath BANG,so tell me how by telling him to use a 60A connector suddenly makes this alteration now so safe ?
J
shocking_eg
  • #14
Im out ! CBA to argue. haha
darkwood
Mod
Mentor
FFS !
Never said anything was your fault??... just relaying the fact the OP is clearly not an electrician, the manner of your comment POST 6 give a suggestion to OP to just go ahead and do it just because everyone else does, then your next post expresses 90% will go ahead and do it regardless of our advice.. well that may be so but its not an excuse to ive poor advice, we are here to assist where we can and explain the bounderies when needed when ask a question, if you feel your getting shot down all the time then maybe you need to look at the contents of your posts and not cry victim, if you dont understand what this forum is about sit back and read through various threads or dont bother at all, youll find anyone else including myself will get shot down for crap advice but just take it on the chin and hold your hands up too it like most do.
shocking_eg
  • #16
Totally fair comment mate. - sometimes best for me not to give advice. only watch and smile :)
darkwood
Mod
Mentor
Totally fair comment mate. - sometimes best not to give advice. only watch and smile :)
Wasn't having a dig Shocking_eg was trying to give constructive advice and was a little supprised by your response it seemed a bit snappy and short tempered but glad to see this comment and that we haven't made you bail ship :)
shocking_eg
  • #18
I know, i didnt mean to !
sorry guys !
just felt like i was at fault - but i suppose i was encouraging DIY'ers - which isnt good ! lol
shocking_eg
  • #19
on a lighter note anyone noticed we have 3 different Jimmys viewing the thread ? lol
Jimmy Boy
It has absolutely nothing to do with keyboard arguments, it's a judgement call on where you think the OP's level of experience lay, if an electrician had posted that the reply I would suspect have been very different, because in my mind he is canvassing opinion on the best way to extend it, in full knowledge that he will, IR it,R1 R2 it,Zs it and check the disconnection times, and guess what I bet he wont touch it until he checks the main E Bond,advice isn't one size fits all I'm afraid.
J
Jimmy Boy
I'm one of three in the Klingon family..( you have to had read the thread to get that one)
J
darkwood
Mod
Mentor
Cant agree more jimmyboy, i tailor my advice to suit the competence of the OP and when i dont know il ask or air on the side of caution even if it means teaching them to suck eggs, in this case it was clear the level the OP sits at just by his opening post and hopefully while ignoring the intermediate banter he'll be aware of where he stands regarding extending his shower circuit.
darkwood
Mod
Mentor
Just curiosity to OP (jimmyclew250), what are your thoughts now and have you made a decision on how you are going to move forward with this job?
Swicade
  • #24
Gottta admit i've started to wonder at times the legalities of giving advice over forums lately.
For example XdiyX comes here and asks how to do something......XsparksX gives some advice not knowing the full extent of the job (due to limited discription).....it all goes wrong and when XdiyX gets asked why they turn around a say 'XsparksX on electricians forum told me that would be right!'.
maybe just me thinking to hard about it but could it cause some problems legaly?...doubtful and hopefully not but who knows?
Then on the other hand as no sparks can possibly know everything (whatever some may claim) i'd hate to see sparks not being able to get good solid advice from these forums.
Jimmy Boy
Now you know why I am sooooooo careful ! If some numb nut wants to extend a shower circuit with a 5A choccy, well so be it,but I ain't gonna tell him to do it with a 60A just to find said person is dead because the shower went pop.
J
shocking_eg
  • #26
J
So really its just about covering our own arses ?? :nonod:
telectrix
Mentor
could be worse, jimmy. he could convert to a gas shower and blow the whole street up.
shocking_eg
  • #28
Haha
Not sure whats more dangerous lol
Jimmy Boy
Well people like me and many that are a good ten miles in front of me in the experience world come on here and give advice for FK ALL so now thats a problem ?, listen up, no one is obligated to help anyone,if you don't like the advice then jog on.
J
Bulk Workwear - Clothing Suppliers for the Whole Forum Network
Reply to Extending 10mm shower cable in the loft ?? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Top Bottom
