Discuss Extending 6mm cable in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
sivoodoo
Client wants cooker moving and therefore a longer cable run is required, the existing cable tests out fine with >299M ohms and good continuity.
The cable has been run behind old oak panel which client does not want touching, so whats my best option for joining 6mm cable that meets regs?
Thank you
every time I have extended a cooker circuit I have just stuck the cables in a 4" adaptable box and used 63 A connectors, All terminations have been accessible and It had a 230 V sticker on it so as far as i am concerned it complies with all regs, but then I am just a trainee so what do I know lol!
Thank you
hi there
would it be possible to put an isolator there ? done this a few times:)
if i would go with the metal bax and connectors i am not a lover of trough crimping seen quite a few burn outs using this method
the other can you run a new cablef rom else where
cheers
Thanks everyone, think im gonna go for the Wagobox method, (as I just recieved a free sample thru the post this morning!)
tangent
we were using wagos over 10 years ago, suprised its taken as long to become mainstream over here.
i use to do a whole lot of european work and theyve been using them over there for, well for a long time
Reply to Extending 6mm cable in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
