S
SAGE
Ok so firstly I am not a DIY'er but would like to get some info in regards to the following project.
I have a new house (2009) so the main board has rcd protection and the wiring would conform to the regs in that year I am not certain about the month though.
I need to get power to the garage outside (5-15meters away depending where I put the power socket in the garage) but am unsure of the best/legal way to do so.
My first thought was to add a rcd spur to the downstairs socket ring main and run 2.5 armoured cable underground(is there a specific depth?) into the garage and stick a double socket(used for lights and a fridge) which I thought would be fine. However I would like to turn the garage into a pub and do not think that 1 double socket will be enough and I do not want to have some shock horror multiple 4 plug extension lead scenario
I have now thought that it would be better to extend the ring main (not sure of the best way of doing this, just remove a socket and use a junction box?) that does not sound like a great idea but does it meet regs ? I have even thought about putting in an additional fuse box into the garage for better protection but I cannot get a cable back to the consumer board in the house. I would have preferred to do it this way.
I know guys at work with part P but know **** all about electrics so was hoping you proper sparks to help me out
Can a part P person sign this off or do I need a proper sparks to make the final connection ?
