Discuss Extending C/U circuits in the UK Electrical Forum area at ElectriciansForums.net
N
Nicebloke
I appreciate this is a common situation when replacing a C/U and providng the C/U is not on display as such I have usually just added a junction box in the past to extend the circuit. Where there is sufficent space to extend a circuit inside a C/U I can't see any problem with using a wago connections, unless someone can tell me otherwise?
Reply to Extending C/U circuits in the UK Electrical Forum area at ElectriciansForums.net
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
I thought I took a photo earlier but seemingly not. Someone's fitted a joint box to move a consumer unit. It's a refreshingly neat job. Din rail...
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
