Discuss Extending ring main cables in the Electrical Forum area at ElectriciansForums.net
Neptune
I would like to extend the existing 2.5mm T&E cables to relocate a switch.
Can I use a 2 way wago connector for each cable and do they need to be enclosed in a box? Also, will this cause any issues with continuity and resistance testing in the future?
Thanks in advance
2.5mm cablein a switch??? is it a socket or a switch??? use wagos but in the existing box/es. then they are compliant witout using an extra box.
Reply to Extending ring main cables in the Electrical Forum area at ElectriciansForums.net
