I
incubus1980
Hi,
I have a spur in my loft at the moment that feeds off of the ring main. I wish to put another socket up there and not have to worry about the load on the cable so i've run a 2.5mm cable down the trunking into the socket where the spur was connected with the intention of extending my ring into the loft.
I'm not 100% sure about the best way to join the cable. I have this: B&Q Crimp Tool Connector Kit & Ratchet, 5052931109418.
From what I have been reading people are saying you must use a ratchet crimper and the blue butt connector for the live/neutral and the red butt for the earth. I can't find any markings on this kit or the connector anywhere online. Does it seem ok to use this kit to join the solid core cable?
For info, I've made a few test joins with the kit and they are absolutely solid. I can't pull them apart. I also used heat shrink and they will be accessible for inspection as they will sit in the box behind the face plate. Mechanically it is solid but i'm worried about the integrity of the connector once it has a current load on it i.e. is it likely to melt?
Cheers,
John.
Cheers,
John.
