Discuss Extent of testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
conrad
200 A 3phase cutout bs88 fuses... manweb said they wouldnt connect the installed 95mm tails for the installed 100ma rcd for temporary site ofiices etc this supplies a large 3 phase board that currently supplies a smaller 3 phase board from 100 amp 3 phase mcb... If i installed the last 3 phase board and circuits from there and others installed the rcd, 1st 3 phase board and supply cable to our board would we be required to supply the certification for all etc? May not be very clear the way ive tried to describe... Also the issue with manweb saying they dont connect the tails in to there cutout and thqt we should? Cheers
It's up to the dno (manweb in this case) to either connect the customers cables or allow safe access for the customer to connect them ie: connections at the top of the ct chamber not in the head. Search the mocopa agreement there is a section on new connections about what the dno and meter operator is responsible for.
Reply to Extent of testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Hi everyone, Quick question can you fit an RCD without any neutral connections? If I have a 3 pole circuit breaker which has all 3 poles...
