Discuss External compressor cabinet in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Supporter
Supply to a nice look compressor cabinet,for pumping up tyres.
16amp 230 v.
20amp rcbo supplying the plug & play unit.
Its outside ,does this require main protective bonding,personally I dont think so.
Its extraneous but not entering the building.
Reply to External compressor cabinet in the UK Electrical Forum area at ElectriciansForums.net
Hello, Carrying out remedial work on a commercial site and I've come across a metal out building that has a water supply to it. The water pipe...
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
Hi, this is a repost of the initial in diy as the only potential diy aspect is the prep ahead of a qualified person attending, this is hopefully...
Have an existing old client with what's best described as a sprawling small-holding of a property. There's an armoured external supply which...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
