Discuss External junction boxes in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Supporter
Quite like these,for various connections,hate the connectors inside though.
Wondering would you use compression glands on entry for flexes or pierce through the sealing membrane../neoprene to seal/hold the cable.
I always use compression glands with them. I never like to depend on external clipping for strain relief.
You can buy them empty without connectors but most suppliers seem to stock the ones with the mountable connector strip.
Same here Andy we usually get them supplied empty though if you are installing an SWA into them you need the earth attachment as you can not use them with a earthnut as the thread is not long enough.
use flex glands every time. screwing the gland in breaks the neoprene seal, without you needing to cut it away first. with SWA, you can use banjos on the outside.
Agree they are ideal for Swa connections,I’ve seen a lot without using compression glands,& seems ok.
Impossible to get the nuts on In those boxes,so banjos are external.
External glands,the boxes are threaded,& screwing the gland to the box,theres no way a locknut will fit into it.
Banjos are external.
Earthing nuts do not fit them you are supposed to use these neater than lashing a banjo on the outside.
This is the correct item you use for those types of boxes as the thread is not long enough to bite the Parana earthnut. Wiska is a manufacturer they also do a smoothed faced adaptable box that you drill and the wall thickness is such that you can fit an earthnut around the gland thread.
Always use glands with them and either strip connectors or wagos depending on how many I've to terminate inside.
Never use the connectors inside, although the brass part can be used as a nut for some outside lights if you drop and lose it lol just touch up with a black marker.
Reply to External junction boxes in the UK Electrical Forum area at ElectriciansForums.net
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Hi, Hopefully I haven't made an error but I was speaking with another electrician and he said standard junction boxes with screw terminals can no...
I needs to install 7 external bulkhead lights, but I could do with a steer on bringing the cable into the light - see below The glass which came...
Hi Everyone, Sorry in advance if this is a silly question. There is a junction box in my mother's kitchen, on the wall above her kitchen...
Hi All. What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ? I am connecting a BG...
