Discuss External junction boxes in the UK Electrical Forum area at ElectriciansForums.net
Same here Andy we usually get them supplied empty though if you are installing an SWA into them you need the earth attachment as you can not use them with a earthnut as the thread is not long enough.I always use compression glands with them. I never like to depend on external clipping for strain relief.
You can buy them empty without connectors but most suppliers seem to stock the ones with the mountable connector strip.
I’d personally never use a banjo outside the enclosure if the enclosure is located outside open to the elementsuse flex glands every time. screwing the gland in breaks the neoprene seal, without you needing to cut it away first. with SWA, you can use banjos on the outside.
Well there are two ways of doing it, lash or use proprietary parts.Ok,the Swa gland thread does not reach the inside of the box,can’t see the problem lashing the banjo to the outside.
Volt drop on an international shed supply must be horrendous.Only ever just use the neoprene for international like in a garage or shed.
Outside gland every time
You must be doing something wrong then. Are you, maybe, using internal rather than external glandsthe Swa gland thread does not reach the inside of the box
This is the correct item you use for those types of boxes as the thread is not long enough to bite the Parana earthnut. Wiska is a manufacturer they also do a smoothed faced adaptable box that you drill and the wall thickness is such that you can fit an earthnut around the gland thread.Earthing nuts do not fit them you are supposed to use these neater than lashing a banjo on the outside.
Reply to External junction boxes in the UK Electrical Forum area at ElectriciansForums.net
