Discuss extra earth in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
C
christian
I have a cooker feed (4mm radial), two 2kw heaters inthe kitchen of an extension and conservatory, do i need extra earthing( to pass building regs) at these points, if so what size ? Cheers guys
Hi Christian,
Not entirely sure what you are asking about extra earthing?
Could you elaborate a bit?
Hi jason.I've just started a kitchen extension rewire.I've done the ring with a fan spured off and cooker hood spured off with a 13 amp connection, (seperate spurs).The problem i have jason is two heaters 2kw (16amp 4mm ring on there own circuit) and the 4mm radial for the 2.4kw oven.Now i was 2nd fixing new build flats not long back (2 years) and i remember the heaters were electric and they had a seperate earth aswell as the 4mm twin and earth.Think it was a 6 mm earth.Is this neccessary for it to be signed off or am i being paranoid???I have'nt got my part p and i dont want to fork out £150 for someone to fail it on something i've overlooked ! Thanks for your reply Jason, its appreciated !p.s i'm sure the cooker and hob had one aswell
Hi Christian,
Hey mate.
I see you've got a ring main for your socket outlets, a 4mm radial for the oven, I get a bit confused then as you say you have a 16A 4mm ring for each heater??
The socket outlets and oven are perfect but I would say that a 16A radial for each heater is more than adequate is this what you mean??
I cant see why you would need an additional cpc as the cpc's in the T+E's are more than sufficient.
How long are the circuit runs?? are there any other factors involved??
Let us know.
Cheers.:D
Hey mate.
Let us know.
Cheers.:D
Hi lenny, sorry,it was'nt clear enough was it.The heaters are on the same circuit (ring 4mm).I thought it was odd with the extra cpc in the new builds that i done.The runs are about 6 metres long max ! Cheers lenny
I don't quite understand why some installations have extra cpcs going to equipment. I can only imagine the installers felt the cpc in the cable was undersized or the readings were too high with only one?
I would have thought that two 2kW heaters on one 16A MCB is a bit much, as each heater will draw 8A. In my experience at work that trips the MCB after a short while. Personally, I'd put them on a 20A.
Reply to extra earth in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
HI All, I am building a new house (self build) and have my part P so am running the cabling. My reading of the regs says that any appliance of...
4K
Hello, I need to run a mains spur off the existing ring main in a domestic property. To get the double socket to the correct place I have to drill...
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
There is a severe lack of sockets in our kitchen. We have a cooker control switch with a single socket in it, but no cooker connected. Would it...
