Discuss Extractor fan ducting in the UK Electrical Forum area at ElectriciansForums.net
Hi all
Have an en-suite that needs a shower light extractor combo fitted. Can’t fit the ducting grill outside due to grade 2 listing.
Does anyone know of an alternative for the ducting to extract the moisture/air.
The ducting will be going into the loft area.
May want to look at what the maximum length of flex duct is according to regs. 1.5m max. Plus need to check building regs on ventilation too to check that your planned fan is sufficient may need to run constantly and speed up on bathroom usage etc etc
Reply to Extractor fan ducting in the UK Electrical Forum area at ElectriciansForums.net
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
Evening all, Currently 1st fixing new extension however the existing cooker hood duct which was on outside wall will now be part of new utility...
HI There, I would be grateful if you could help me, I have a very long duct between the bathroom and extractor outlet vent and for sometime, the...
Hi. My current axial Xpelair model 92614AW ground floor bathroom extractor fan is installed in zone 1 and doesnt work efficiently at all. Its wall...
