Discuss Extractor fan in the DIY Electrical Advice area at ElectriciansForums.net
Calonbar
Have just built an understairs WC and utilized an existing light that was operated by a pull cord. (just off/on) I want to install an extractor fan with timer to operate using the existing pull switch. I know I will need a switched live to operate the timer, how do I create one using the existing supply?
Can you show the wiring at the light fitting.
So you only have one cable at the switch, can we see the wiring there.
You will need a permanent live, a switched live, a neutral and an earth for your fan.
Reply to Extractor fan in the DIY Electrical Advice area at ElectriciansForums.net
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
I've installed a replacement bathroom extractor fan. Pic on the left is the old one. Pic on right is the new one. Wired the same way but the fan...
HI There, I would be grateful if you could help me, I have a very long duct between the bathroom and extractor outlet vent and for sometime, the...
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
