Discuss Fan isolator in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I'm also interested to see what code you would give it and why.
No,I am fitting teo fans one in the bathroom and one in the kitchen,landlord does not want isolators as he wants them to run constantly and he thinks that tenants will switch them off just to save energy.Just thinking if it not against regs.Thanks.
Simple way to deal with that is to arrange things so that the bathroom and kitchen lights are fed through the isolators as well.
I thought that the idea of the isolator was to just isolate the fan and not the light, so making it easier for maintenance, if you need the light on?
Everyone doing maintenance on a fan should have a torch of some sort so I'm not quite sure if the above is totally correct.
Maybe someone can correct me.
Minor inconvenience since the invention of the head torch.
Reply to Fan isolator in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Just wanted to get some thoughts from other electricians who regularly do EICRS, does anyone else code a fan isolater with no 3A fuse protection?
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
