Discuss Fan switch in bathroom in the UK Electrical Forum area at ElectriciansForums.net
E
eds54
Hi all
Can i put a fan isolation switch in a bathroom 2m from the bath and sink and above the height of the door. I should look it up but i thought i would ask you guys
Cheers
I could but there is already a pull cord switch for the lights and another one would look messy but if thats what its got to be so be it
Hi all
Cheers
The reg's say 0.6m out to the side/front & 2.25m above the bath. However, a pull cord is the way to go for me. Locating any switch above the height of a door automatically renders it inaccessible to me. How will you operate the switch in an emergency?
Poke it with the netty brush. ;)
Only problem I see that raises debate to me is that even though outside the zones an isolator switch usually does not have an ingress protection against liquid. I have fitted inside bathrooms lamp plate switches before; but one could argue it's not in line with bs7671 522 - if they were punctilious - and on an open forum they usually are :)
I wouldn't bat an eyelid installing a light switch, fan switch, or whatever in a bathroom using commonsense to guide me!! But i can't be arsed arguing with the blinkered mass on here, that think bathroom installations are sacred places where electrical functional ability has no place!! lol!!
LOL, it's not just on here. E54. They get flagged on PIRs (not by me) and even BC sometimes ask questions. As stated, I have put them in but to save arguments re "fit for environment" I dont suggest or imply to the customer that I can. IE I assume its going to be outside or a pull cord.
Regards, David
Reply to Fan switch in bathroom in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
Hello, I currently have two switches in my bathroom. One controls the lights above the sink and the other controls a light above the toilet and...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
