Discuss fault finding - lighting in the Australia area at ElectriciansForums.net
T
tom-the-sparky
Hello Everybody
I have been a spark for 3 years now and have encountered a problem that i cannot fathom, very frustrating, please can u help?
A client suddenly found that two lights, one in a porch and one outside light had stopped working - no other information 'just stopped working one day'
I thought it would be a loose connection some where, couldn't find one. The rest of the downstairs lights, which are on the same breaker supplying the dodgy lights are all working fine. Also when you make the switch for the porch light live and earth are at 230v but nothing between live and neutral!
Has anyone encountered such a problem before?
If you close the switch they (line and switch live) will both be at 230V so putting a voltmeter across them will show 0V. Testing between either of them and the cpc should show 230V.
When the switch is open you should have 230V between L and switch live; and 230V between L and cpc.
Edit: you need to be checking continuity.
lost neutral somewhere. check from last working light in the house. you'll possibly find a loose or broken neutral in the rose.
Hello Everybody
I thought it would be a loose connection some where, couldn't find one. The rest of the downstairs lights, which are on the same breaker supplying the dodgy lights are all working fine. Also when you make the switch for the porch light live and earth are at 230v but nothing between live and neutral! Is there a neutral at this switch or are you testing between the LINE and the BLACK/BLUE switch line?
Thanks[/QUOTE)
It as to be either a loose or burnt out connection from the last light that is working to these 3
Cheers for this guys
Yes no neutral at the two gang switch controlling the two dodgy lights. Ive also checked at the nearest and only accessaible junction box and all seems in order. BUT i didnt check at the nearest downstairs light, so you think it must be a loose neutral?
thanks
Reply to fault finding - lighting in the Australia area at ElectriciansForums.net
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
Hi folks, Quick query for this still practicing regarding bill payment for a job not complete. My partner recently employed an electrician to do...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
Hi everyone, I'm new to the industry(Qualified a few months ago). I have a client with 6 LED light fixtures on the same circuit/breaker, 3 are...
