Discuss fault finding in the Australia area at ElectriciansForums.net
R
Robo
My light in garage has stopped working. the other light has 230 v supply tested. when i test the voltage at the sw side of ceiling rose feeding light it only has 20v.
Any1 shed any light on this and would it stop the light working??
thanks
Thanks mate. I will check the neural connections. Out of curiosity at what sort of voltage would a ligt stop working?
Reply to fault finding in the Australia area at ElectriciansForums.net
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Hi There is a lighting circuit fault in a property with the downstairs lighting circuit. I have tested the voltage and there is 230v on both...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
