Discuss Fault on lighting circuit in the Industrial Electricians' Talk area at ElectriciansForums.net
s6stu
Hi people,
I've got to give a price to do a few works at a house, which includes fixing a lighting fault and was hoping to get some views of the problem beforehand.
The problem is with some low voltage downlighters, after about 10 mins, 2 of the lamps become really dull (always the same 2) while the others remain constant. Then after another few mins they return to full power?
I'm thinking there has to be a problem with the transformers.
Any suggestions?
Hi,
if the transformer is the problem why does it work ? the only way it can break is if it goes open circuit or breaks down between windings ,both of which are perminent situations ,i would check for a loose connection and that there not wired in series first ,also swap the transformer with the ones that work before condeming the poor thing ,
good luck
Reply to Fault on lighting circuit in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi There is a lighting circuit fault in a property with the downstairs lighting circuit. I have tested the voltage and there is 230v on both...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
Hi, I have an a single LED (240v Robust Fixed, LAP GU10 LAD 250 Lm 4w) downlight which is going through a squence (after being on for a while), I...
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
