A
axel132132
Hi all,
my auntie has moved into this house that has had a part rewire - the full house has been done apart from the shower and the kitchen. She has a new split rcd board
the issue is this she says when she first moved in the rcd kept tripping when drills, vacs etc were plugged in then this eventually stopped and she could use her vac.
she then said she had a new shower installed its a 9.5kw shower and the existing cable is 6mm on a 40a breaker - now when you turn this on it works fine, low setting fine, medium setting fine.. Put it to its hottest and it trips the RCD
at first i thought prob the small cable but then im now thinking could it be the RCD or a faulty shower because surely if the cable was too small it would trip on a low setting also and wouldnt it trip the breaker not the rcd
i would test the rcd but my test meter has just broken
please advise as i was suggesting trying to swap the rcd and then possibly the shower but if this sounds like the cable i can then inform them that the cables too small and she needs to rewire it
