Discuss Faulty integrated fridge freezer in the Australia area at ElectriciansForums.net
B
Bjorn Aaen
Hi all
Hope someone can assist?
I have an integrated ariston fridge freezer model bcb 3111 that is just over 7 years old.
The freezer functions normally.
The fridge is cold but not cold enough for milk to stay fresh till it's use by date.
I clump of ice forms near the top of the inside of the fridge. Water gathers at the bottom of the fridge.
I have defrosted the fridge/freezer and also ensured that the water pipe at the back is unblocked. I have turned it back on. The problem repeats (temp not cold enough, ice forming at top of fridge, water gathering at bottom).
I almost bought a new unit yesterday but would like to try one last time to fix rather than replace.
Any advice very much appreciated.
Bjorn
I had a similar problem with a fridge freezer, it turned out to be because the dog slept in front of the doors! At the bottom of the fridge was the cooling fins behind a smalll pull off vent panel which was covered in dog hair, after I spotted that, and a quick vacumme later, it worked properly for ages after that.
Could be a blocked condensor or a condensor fan that's packed up. Climb around the back, clean the condenserif there is one visible with a vacuum cleaner or brush and check the fan runs whenever the compressor is running.
If it's a single compressor model then it could also have a gas leak. If the freezer is fed first then it would still get cold but there would be insufficient gas to cool the fridge section.
Reply to Faulty integrated fridge freezer in the Australia area at ElectriciansForums.net
I have a 7 year old integrated Neff K42 fridge freezer and I need to replace a couple of the attached kitchen cabinet doors hinges. In order to...
A few weeks ago I posted this in another thread...: The tripping kept occurring, so I went back and moved a likely candidate circuit to the...
I experienced the common issue of the condenser frosting up so the air can't circulate around the freezer or up into the fridge so it all gets...
Hi everyone. First time here. Wondering if I could pick your collective brains. Our integrated fridge freezer has stopped working. No light, no...
4K
B
I run a small ecolodge in rural Laos and have a floating restaurant down on the river with several fridges. Being where we are, the electricity...
Barns
B
