Discuss Faulty outside lights with PIR in the Lighting Forum area at ElectriciansForums.net
Recently i've fitted 3 outside lights with PIR, next to customers front door and one on my own garage, the £30 to £45 ones from screwfix...they last between a week and 6 months then go faulty... so i have to keep going back... any ideas..
To be fair, two are from screwfix and the one i have is from a wholesaler i used to work for... I suppose i was hinting at, is this a common problem with cheap outside lights!!
What does "For Lap read crxp" mean?
he means that , in his opinion, LAP are crap. TBH they're not bad for budget range gear, but the reliability is obviously not as good as someof the better known, more xpensive brands.
having said that, i fitted a 30watt LED flood and PIR at home 2 years ago.higher price range as it was £40+VAT. it packed in last week. the driver is not driving any more. opening it up, the driver was made in China, same as the cheapo versions. these days it's pot luck, whatever brand you go for.
Take em back, get refund and get some decent ones, Lap = shyite
This is what I got in mind;
Not sure about the colour. Damn wrong thread. Whatever.
I fitted some LAP barrel lights that a customer supplied, two out of four failed in 12 weeks, I changed them over for some replacements that screwfix gave the customer....All four have now failed after about 6 months. I told the customer £120 + VAT to go change them over again which I think is pointless. I would never supply lap fittings as I would be forever returning to jobs on warranty.
I thought it was frowned upon for you guys to install parts that the customer have bought, for this very reason.
It normally is but the OP would more than likely have got the fittings from screwcarp anyway.
Reply to Faulty outside lights with PIR in the Lighting Forum area at ElectriciansForums.net
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
Hi all, Just a quick one, I want to use an ip rated light switch with a neon indicator to manually ovveride a PIR detector controlling an e27 LED...
Maybe I've just been lucky, but I very rarely have an issue with customers paying, the vast majority have paid straight away or within a few days...
Driven by the recent colossal hikes in the cost of electricity I hit upon the wizard wheeze of replacing some of the existing LED bulbs in our own...
